Help with designing custom controller for GEV craft
Hey guys!
As part of my Master’s thesis, I was trying to design a controller for controlling an aircraft in ground effect to maintain the exact altitude. I began looking into this as we felt flying the plane using the exsisting TECS controller in FBW-B was not very stable and we needed a more reliable way to control the aircraft.
Since I just began work on this like a month ago, this is the plan I had come up with:
  1. Familiarize myself with the entire ArduPlane architecture and learn a little bit of SITL with Gazebo
  2. Create a non-linear model of the aircraft with data from real System Identifcation flight tests
  3. Read the source code for ArduPlane and recreate the same in Simulink or MATLAB or Python for understanding the system’s properties such as the limitations and have a more clear understanding of how ArduPlane works if I need to modify it. Rather than treating it like a black box, I wanted to understand the architecture deeply to know where I can modify the low level controllers if needed for our particular system
  4. Actually implement the controller and conduct flight tests
I have over a year for this and I am working with a small team of engineers on this as well. But none of us have any idea on how to go with Step 2
I am also actively trying to recreate the non-linear 6 DoF model of the plane using test data so that I have a platform where I can build these controllers
The existing code base is huge and we don’t know where to start. And even if we do, it is hard to actually understand where the inputs are coming from and where they are going
Due to this, we were contemplating if this is a good way to go about it in the first place but at the same time we have been persistent on recreating it so that we are clear with how to proceed later on.
Again, the goal is not to recreate everything, just the relevant parts such as the signal flow from sensors to the EKF to the TECS then to the pitch controllers. And the L1 controller as well. As it maybe relevant for future work.
Any advice would be really helpful. Thank you everyone!
My education background for reference: Undergrad in Aerospace and currently doing my Master’s in Control Systems
TECS doesn’t sound like the correct choice for controlling GEV.
Personally I would start with work on modeling ground effect accurately, with correct model of wing in ground effect deriving vehicle model should be pretty easy. Then you can close the loop using PID cascade and start identifying where nonlinear controllers and other constraints are needed.
L1 takes care of lateral navigation so it is orthogonal to controlling airspeed and height above surface.
