smartdave
(Dave Glover)
April 20, 2020, 2:34am
#1
I am having a super hard time calibrating my external compass. It is a Neo V2 Pro CAN compass.
I am not new to this compass as I have 4 others that work perfectly fine.
The CUAV Nano V5 compass calibrates just fine, but the external one no matter how many times I try.
I am however getting these messages and not 100% sure how to interpret them.
Mag(1) bad radius 385 expected 516
Mag(1) bad radius 371 expected 516
I was also getting a few of these:
4/20/2020 12:16:04 AM : PreArm: DCM Yaw inconsistent by 150 deg
4/20/2020 12:15:34 AM : PreArm: DCM Roll/Pitch inconsistent by 135 deg
I also tried by not Using the internal compass and just trying to calibrate the external.
Its possible that it could be hardware, but figured I would as this brains here first.
Thoughts?
Dave
smartdave
(Dave Glover)
April 20, 2020, 4:20am
#2
I just also plugged in my normal Neo V2 Gps Antenna and that calibrated right away. So I guess Hardware issue
omi24
(Omkar Pande)
April 20, 2020, 5:47am
#3
First update the firmware .
2) calibrated compass in open area where no electronics are connect like backyard
3) set compass arrow in north direction
4 ) used different compass hardware in case if still error found .
Try calibrationg one compass at a time instead of multiple compasses at once.
smartdave
(Dave Glover)
April 20, 2020, 12:23pm
#5
I have tried to do them one at a time. My normal procedure is to disable the internal one and just work with the external. When that failed I started trying different things
Again I have 9 other crafts that do not exhibit this issue
smartdave
(Dave Glover)
April 20, 2020, 4:11pm
#6
Just to 100% verify that it is the compass… I made a test jig and connected the GPS to a spare V5+ FC and tried to calibrate… Still no dice.
norim
(Norimbo)
April 20, 2020, 5:44pm
#7
Maybe change to “relax” setting for calibration…and after that try to compass learn function during flight…
smartdave
(Dave Glover)
April 20, 2020, 5:46pm
#8
I have done that, plus change the offset max to 3000.
This compass is DOA, the replacement has already been shipped
smartdave
(Dave Glover)
April 20, 2020, 10:35pm
#9
Well the compass is broken, but the GPS is working fine.
I thought I would play around with GPS blending until my replacement comes in.
One CAN (the broken one) and one normal SPI/UART
