Please help me identify plane crash cause.
I have several years experiance flying Ardupilot sinceAPM time, all crashes have been user error or hardware. Limited expeience in LOG analizing won’t allow me to determine cause for these crash.
This time Pixhack 1 was installed with Ardupilot 3.9.0 beta 6 installed. equipped with air speed sensor and external compas, two GPS units as well.
After takeoff in FWBA A , gained some attitude ,made couple cycles around myself and switched RTL to test before proceeding to make 20-30 km FPV flight . Plane sudenly made a sharp dive to the ground. I was able to switch to FWBA A for recovery and gave full up elevator but plane just dove down even stiper. during dive wings stayed level in plane flu in strait line.
It was not first flight with that set up. Had some strange behavior but was able to bring it back for safe landing.
Please help me identify issue , weather it is software related or setup/user error!!!
Autoanalisize tool gave me below results:
Log File C:\Users\votolok\AppData\Local\Temp\tmp90CF.tmp.log
Size (kb) 39172.88671875
No of lines 481225
Duration 0:07:43
Vehicletype ArduPlane
Firmware Version V3.9.0-beta6
Firmware Hash ce7b5345
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Brownout = GOOD -
Test: Compass = FAIL - FAIL: Large compass offset params (X:-490.29, Y:-238.51, Z:-46.48)
FAIL: Large compass offset in MAG data (X:-490.00, Y:-238.00, Z:-46.00)
Large change in mag_field (119.45%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = FAIL - Check vibration or accelerometer calibration. (Mismatch: 1.95, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = NA -
Test: NaNs = FAIL - Found NaN in POS.RelOriginAlt
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = UNKNOWN - No CURR log data
Link to bin file https://yadi.sk/d/-g_5lj19E9Ondw
