hello @khancyr
Could you please help to connect the l89 gps module with pixhawk 4 along with pixhawk4 gps module
the pin diagram i follow for l89 chip interfacing at serial port of pixhawk
also is this chip compatible with pixhawk
am i missing anything here
khancyr
(Khancyr)
2
hello,
connection is explained page 21.
hello @khancyr
thank you for your reply
yes but i need to know about pixhawk parameters setup
khancyr
(Khancyr)
4
there is no such thing as pixhawk parameter. Pixhawk is an electronics board, it does nothing itself.
So I will assume that you are using ArduCopter :
GPS_TYPE : NMEA Complete Parameter List — Copter documentation
SERIAL3_BAUD : your gps baudrate (probably 9600 which isn’t great) Complete Parameter List — Copter documentation
@khancyr
- Thank you but it does not have a compass in l89 module is there any method to solve this
also another issue i am facing is
2)for obstacle avoidance in
mission planner has only a2 lidar option in telemetry1, can we use this a3 rp lidar
if yes how to set it up
