Helo Pixhawk 2.4.8 AltHold Unsteady (Analyze Log File)
How about in the first video? It is in Althold mode also.
Can I used Loiter to take off then switch to Auto Tune after? Then once complete switch to Loiter for landing?
about your throttle :
also you can reverse CH3 in parameter list just search for RC3_REVERSED and change it
you can take off with loiter and also autotune your copter in loiter mode
But i dont have chanel 7, I will just use Auto tune as flight mode, after take off I will switch to Auto tune mode. Then once complete, switch again to Loiter for Landing. Will it Hover on Loiter mode?
I will try on doing the things you all suggest, for now my propeller was damage i cannot test it. But already taking notes of all the suggestions.
Maybe by monday we will try flying in loiter mode to perform Auto Tunem but loiter needs GPS right? Which is better, GPS external or Indoor?
Once all the problem has been fix, next step is to perform mission flying/
takeoff with loiter then switch to autotune and after autotune is completed land with autotune mode to save PIDs.
indoor you will never get GPS lock
If you want to avoid the drifting you should trim the FC. Best is inside because there is no wind: http://ardupilot.org/copter/docs/autotrim.html
Okay, so I can still Land with Auto Tune flight mode? Is this required to land with this flight mode to save the PID?
How does Trim works? I dont have CH7 my transmitter receiver is only 6 channels. :frowning:
Read here: http://ardupilot.org/copter/docs/autotrim.html
yes you can land with autotune and its necessary
Hi all, thanks all for the help and suggestions you provided. Im still waiting for the new motors and later on will be testing it then AutoTune. I hope that I will fixed this issue soon, so that I can move on to mission flying then later on finally used Camera. I will be updating from time to time.
Sir, need your help. Will this motors okay? Thanks.
Those are good motors. Also possible t-motor air gear 450. they are even better:
Thanks. DO you have any idea how Can I used compass internal and external, that for example if I will be flying on stabilise mode it won’t be needing GPS then automatically it will use internal compass? Cause I always remove external compass every time I tried indoor.thanks
You don’t need to remove external compass when you fly in door at all
Compass order will not change by changing flight mode if you set external compass as primary it will be main compass in all flight modes
Hi Sirs, this is my recent flight log using the new motor in AltHold Mode. So far didnt get the chance to try yet AutoTune because of small area. Please help me analyze if there are still vibrations and problems. Thanks
you have to hover your copter at the least 1 minute for good vibration measurement
but in this log vibration is OK and don’t worry about clip graph it because of crash
Hi Sir @hosein_gh, this flying test is about 2 minutes. Also, it is hover in the middle of the throttle in AltHold Mode, but I keep moving the stick because the drone is moving. What do you think?
I will try Loiter Mode on the next flight so that I will steady in hover then AutoTune using GPS outdoor, will that be okay?
This is the video of my drone flying in AltHode Mode:
your copter moving in AltHold Mode is normal and OK
yes it will be OK
Hi Sir @hosein_gh, this will still needs Auto Tuning?
Also Sir, regarding the reverse up and down on my transmitter, you suggested that I should set RC3_REVERSE to 1, when I tried to set it, my copter wont ARM, but when I return it to 0 it Arms, is there any other way so that my transmitter up and down stick which is reverse can be fixed? Thanks.
