Heli servo output problems
Hello
I’ve started to setup a 450 and a 500 with APM 2.6. I think i’ve connected input and output correctly. Unfortunately I cannot get the input signals to move the correct servos. Ch2 - ele input is also moving the tail servo. Does anyone know if I have to change a setting in mission planer ?
No, you shouldn’t have to change anything for that.
How much is it moving? Just a tiny bit?
APM2.6 is very old, the firmware for that is probably 2 years old?
I’ m using fw 3.1.5.
I tried the same on a apm 2.9. It’s showing the same problem. The movement is about 50 up and down on all flight modi, except agro mode.
Will the heli fly with the movement on ch4 ?
Try to increase the output of the power steering gear to Ubec of 5.5-6v
Hi … I’m using 6 V output.
