First of all I want to thank the development team who has worked so long on this project and without whom it would not exist.
I’m trying to settle a flybar helicopter equipped with a 2.6 APM and all the recommended 3DR equipment , and it goes pretty well, I have test the Loiter mode today, and despite some adjustments to make, it is rather encouraging.
There is a point that I do not understand, when I’m in STABILIZE mode, everything works normally, but in ACRO mode, I do not have cyclic control.
I looked for any parameter which could neutralize the cyclic but I have not found.
I followed the procedure of PID tuning on the WIKI …
If I chose a FBL heli in MP config then ACRO mode works fine, is this normal?
thank you for your help
ps: sorry my english doubtful, I’m French and Google translate is my friend: o) …
thanks for your work.
I’m not sure to understand, you mean that the code 3.1 is ok and it’s pobably a config problem, or the new code (3.2) is now ok ?
I noticed the same thing setting up my FB Min air machine on the bench. also, I noticed the collective moving to full negative when switching from stabalize to loiter.
