Heewing 405 flight controller switches between modes when motors start. With motors off no movement between modes unless selected by user.
I guess the answer is in bin log file.
… and also eventually in the wiring setup
I only have 1 motor and 1 tilt servo setup on the bench. The motor s plugged into #7 and the servo plugged into #5. All per the manual. Without the motor running the mode switch controls all movement. There is no movement unless the switch is used.
Starting the motor and then making one mode change by switch starts the continuous movement of the tilt servo.
