I am running two TF-02 lidar’s…one for downward facing terrain follow and one for forward facing and simple object avoidance. I can only get the one facing down to work in flight…it follows the terrain well in Loiter Mode. The forward facing one is not stopping at the avoid_margin I have set up as 7m. I have triple checked and all the avoid parameters are setup correctly.
I am using Telemetry 2 and GPS 2 serial ports. The downward facing one is on Telemetry 2 and using Serial 2. The forward facing is on GPS 2 and using Serial 4. In Mission Planner I am getting accurate readings from them both and accurate readings on my Herelink. I have checked the forward facing by hitting Control F and going to the Proximity Tab and it shows it reading correctly forward in meters.
I have got them to work individually on the Telemetry 2 Port, but despite good readings I am not able to make them both work in flight…only the downward facing one works.
Hi @DoubleD4485,
From your question I understand that you tried to stop your vehicle at 7 meters from a static obstacle and the vehicle did not stop? Is that so?
Can you please share your logs (.bin file) from that particular flight. I’d like to verify a few parameters + if the range finder readings were healthy.
@DoubleD4485 thanks for the logs
It seems everything is fine apart from one little problem… You haven’t configured your proximity params…
i.e PRX_TYPE (which is set 0 for you)
You need to set it to 4, as rangefinder
Without this parameter, simple avoidance or path planning nothing will work.
At the same time I would suggest you to configure any one of your vacant channel on your RX as a toggle switch for proximity avoidance
The corresponding parameter would be : RCX_OPTION and value will be 40
Incase something wrong happens with your sensor, (although it should not happen) you can simply toggle the switch to “low” position and proximity avoidance will be turned off. Remember to switch it to high during flight to get the avoid obstacles!
Cheers
Hello @rishabsingh3003, I am also facing an issue using two sensor. One is TF Luna on I2C1 and second one is TF02 Pro on serial4. I want luna for altitude hold and pro for obstacle avoidance. Both sensors are working when I set them to downward facing but as soon as I changed any one sensor to front facing, data from that sensor gets stopped. Also, I could not get the PRX parameter working. Can you share you parameter list?
