I was looking at a .bin file related to a crash earlier this year. To my surprise I found a voltage increase on the servo rail just prior to events unfolding which led to a crash.
I had a look at the wiring diagram of the Pixhawk 6X which was in use, but appears all PWM outputs are isolated by optocouplers. Also the control wires of the ESC is only a 2-pole connection.
Perhaps someone has come across a case where an un-commanded low throttle output occurred ?
That looks like ESC/Motor2 was not producing thrust.
The current should probably have gone down (not up) unless there was a short.
It would be handy to see the .bin log.
Dont place too much emphasis on the current and Vservo doing odd things unless you are sure they are actually wired up correctly (and the correct pins are selected) because they are high impedance inputs and can float to all sorts of crazy values. For example if a voltage reading is going up with a current reading there’s a good chance the voltage pin is incorrect or not connected to anything.
