Hi everyone,
I’m looking for guidance on the Harmonic Notch Filter configuration for our Y6 QuadPlane and would appreciate recommended parameter values based on the measured vibration spectrum.
Aircraft setup:
Y6 QuadPlane – 6 lift motors
30" 2-blade propellers
CubeOrangePlus
ArduPlane 4.6.3
ICM45686 primary IMU
Normal PWM ESC control; no DShot/Bidirectional DShot
ESC RPM telemetry: ~10 Hz with ~4% dropouts
Hover RPM: ~2558 RPM (~43 Hz fundamental)
Vibration data:
VIBE average: ~8–9 m/s²
VIBE peak: ~23 m/s²
No clipping
Raw gyro FFT shows:
1P: ~43 Hz
2P: ~85 Hz
3P: ~127 Hz
4P: ~169 Hz
5P/6P: near noise floor
Current Q_M_THST_EXPO = 0.77.
Questions
With no Bidirectional DShot and only 10 Hz ESC telemetry, should we use throttle-based notch (
INS_HNTCH_MODE=1), or is the ESC telemetry usable for frequency tracking? -
With measurable energy up to 4P, what would be the appropriate
INS_HNTCH_HMNCSvalue—3, 7, or higher? -
What would be a suitable starting
INS_HNTCH_FREQ,BW, andATTfor this 43 Hz fundamental and 30" prop setup? -
Is the harmonic notch worthwhile given the relatively low VIBE levels, or would you recommend tuning without it?
Does
Q_M_THST_EXPO = 0.77require any consideration when using throttle-based frequency tracking? -
Any concerns with enabling the notch on both IMUs of different types?
I will attach the .bin log and Filter Review results.
The main objective is to determine the least aggressive notch configuration that adequately attenuates the measured 1P–4P harmonics while minimizing phase lag.
Thanks.
