Hi everyone,
I’m trying to set up a Hardware-in-the-Loop (HIL) simulation using a Cube Orange+ flight controller with FlightGear.
I found the old ArduPilot documentation describing FlightGear HIL:
https://ardupilot.org/dev/docs/flightgear-hardware-in-the-loop-simulation.html
However, it appears that this documentation was written for the older APM/Pixhawk workflow, and I understand that HIL support may no longer be actively maintained.
My goal is to use the actual Cube Orange+ hardware as the flight controller while FlightGear provides the aircraft simulation and visualization.
I would like to know:
Has anyone successfully implemented FlightGear HIL with a Cube Orange+ recently?
Is the old FlightGear HIL workflow still compatible with current ArduPilot firmware?
If not, what is the recommended approach for running HIL with Cube Orange+?
Would a custom MAVLink/pymavlink bridge be the preferred solution, or is there another supported method?
Any guidance, examples, or references would be greatly appreciated.
Thank you.
