Does anyone have any idea if there is a custom hex or something for the HAKRC F405 WING? This was falsely advertised as compatible with Ardupilot, which I suppose may be true on a technical level, but on a practical level there is not any firmware target openly available. In hindsight I should have done my research beforehand but to be honest I mainly make 3D printed airframes for fun. My buddy wanted to test out some scripts he wrote for ArduPlane so I told him I would make him one. Somehow I pick the only F405-Wing board without ArduPilot firmware. PLZ HELP BEFORE I DROWN IN MY OWN TEARS THANKS
Looks like you’re out of luck.
Here’s some good sources for what to buy on your upcoming shopping trip:
Should also point out if you want to run scripts you’ll want an H743, not an F405. Can’t run scripts on F405 boards.
To be clear, you cannot run onboard Lua scripts on F405 boards, but if your scripts are offboard (like pymavlink based Python scripts), those may be ok to test against the smaller, less capable hardware.
Yeah sorry, I should have clarified the scripts in question are running on the ground station via MAVLink, not the flight controller itself, but the mission planner being used isn’t compatible with INAV and is going to be mostly relying on sensor input rather than GPS so INAV isn’t ideal for that either, although there will be a GPS sensor via UART. In any case, it’s an experimental personal project and the budget isn’t very high right now. Next FC will be H743 for sure.
