Guided_NOGPS - How to use it?
Good Day,
https://ardupilot.org/dev/docs/copter-commands-in-guided-mode.html
I read “SET_ATTITUDE_TARGET - this is the only message accepted by Guided_NoGPS” and the body pitch, roll and yaw rate inputs are disabled. which mean I cannot control that from Guided_NoGPS mode. The only way is to give it X, Y,Z position target and it will move to that position. Is this correct?
If it is correct it means I need an initial position lock and then a gps denied position estimation device like Optical flow(which I have). So does it mean I need a GPS to get initial position lock?
Thanks in advance!
You need to send a “SET_HOME_POSITION” mavlink message to get the system initialized.
Thanks for your reply!
I’m using mavros for communicating with the pixhawk.
So i came across -> cmd/set_home (mavros_msgs/CommandHome)
  • Change HOME location.
does this correspond to “SET_HOME_POSITION” mavlink message ?
when I am sending this im not getting a success response from pixhawk, unfortunately!
Does it have any prerequisites?
