Guided Mode unstable height
My drone with Copter-4.7.0-dev has unstable height after takeoff, im using rangefinder as ek3_src1_posz and ek3_src2_posz, rangefinder is the lidar from MicoAir MTF-01, im not using barometer because i need to hover around 50 cm above a flat surface.
the behaviour of takeoff with mavros varies in my drone for some reason, if I take off using command line, it seem to hold its altitude quite well, however, when I use it in a script, the drone descend shortly after taking off, I tried using ‘/mavros/setpoint_position/local’ to hold the altitude but it doesn’t seem to be stable
im not sure the EKF is using the rangefinder data, the z position values in ‘/mavros/local_position/pose’ is also unstable even before flight
Have you tuned the altitude controller like described in the documentation?
I forgot to mention, Loiter and Altitude hold seems fine, do I need different tuning for guided?
Guided uses the same controller as loiter.
okay, so there’s no problem with the controller, could added weight (around 100 gram) affect the controller’s performance? my drone is speedybee bee35 with 5 blade props, its a 3.5 inch drone
Yes, it affects the controller performance.
it didn’t affect it much, I tested it in pos hold, the height is stable, how do i replicate that in guided?
