Ground radio not detecting air radio on android
I have tested the radios with mp, paired and worked perfect.
then connected to android tablet galaxy 3 8" , all leds lights up, but the green led continues to blink indicating unable to find the air radio.
Any ideas what to to try next ?
I have posted alsounder the droidplanner topic, but no solution yet , anyone who have experienced this problem before ?, thanks
Link to the issue on droidplanner post
http://ardupilot.com/forum/viewtopic.php?f=15&t=7215&start=0
VIDEO TO SHOW THAT APP CONNECT TO GROUND RADIO, BUT RADIOS CONTINUES SEARCHING EACH OTHER , WITH NO LINK.
[youtube]https://www.youtube.com/watch?v=SZk-Lfqj40w[/youtube]
Can you post a screenshot of your radio settings from Mission Planner? I found that if RTS/CTS is enabled then my android devices won’t connect to the vehicle.
Regards,
Maurice
MAURICE handshake is set to none,
If green LED blinks - there’s no connection between ground and air modem.
Make sure you have “air” part of both modems set for same settings (air rate, NET ID, frequency range etc.)
It might be a good idea to reset modems to default settings.
Both radios are fine, as i said everithing works if i use mission planner with a windows8 tablet, same radios , same configuration,.
This is why im sure both radios are fine , and something is wrong with the tablet usb, but sont know what else to try.
The tablet needs to support OTG (USB hub support), There are some OTG checker apps for android, I think you can give them a try.
Thanks Rogelio , yest Samsung galaxy tab 3 8" supports org host mode, but it ain’t work .
Is there somebody with this tablet that made it ?
