I am trying to integrate a VN300 Rugged with a Cube Orange as an External AHRS.
Attached is my param file, with the key parameters set as per VectorNAV External AHRS.
SERIAL1_BAUD
921 -
SERIAL1_PROTOCOL
36 -
AHRS_EKF_TYPE
11 -
EAHRS_TYPE
1 -
EAHRS_OPTIONS
0 -
EAHRS_RATE
400 -
GPS_TYPE1
21 -
GPS_TYPE2
21
I can see the vectornav library being loaded within messages tab of mission planner on boot and GPS1 can get a 3D fix, however GPS2 says no fix.
Checking the status of the VN300 through the vectornav control center, both GPS A and GPS B are capable of having a GPS fix.
I have reviewed the source code for the vectornav library and I’m not sure if the information from the vectornav about GPS B is actually being passed to the autopilot (my understanding could be wrong and please explain if so)
In process_packet2
, the numGPS2Sats
and GPS2Fix
fields of VN_packet2
are never accessed. It also looks like only one GPS instance is ‘handled’.
So my main questions is: should numGPS2Sats
and GPS2Fix
be accessed at some point and handled by the autopilot?
vn300-config.param (21.0 KB)
