GPS problem pixhawk
Hi.
Im using ublox neo m8n gps module for my pixhawk, it lights solid red and i made calibrations. But when i open Mission Planner it says GPS: No fix. im not sure is my gps working. could you check it
https://linkpicture.com/view.php?img=LPic5f3a952a00cd9798255897
Thanks.
Hi, are you testing this outside? Without sky usually it won’t work.
Most GPS units have a second pulse led. Once they acquire 3D fix, they start pulsing a led every second. And it’s a different colour then the “power present” led.
Also, depending on what’s actually inside, and your view of a clear sky, when powered on after a long time, may take long minutes to find a fix.
Thank you, it work now.(sorry for late reply)
