No. The 5V pad isn’t powered by USB. Most likely, there is some parasitic draw through the TX/RX pins, allowing some current to pass and illuminate the LED. There is no design flaw. It’s all intentional, and you simply need to read the datasheet.
Yeah that is most certainly the case. TX/RX pins default to HIGH when idle, which is 3.3V. The internal ESD diode may have a clamping voltage of about 0.7v which gives about 2.5V to the power rail of the GPS.
I’ve also used DAKEFPV FCs quite a lot. In the first photo you showed, it looks like the wire is soldered to the 4V5 pin.
That pin is intended for the receiver. You should solder it in the order 5V → SCL, which is to the right of the white wire.
The power pad you are currently soldered to is the power supply used for the receiver.
[SBUS | RSSI | T2 | R2 | 4V5 | GND]: Receiver line
[5V | GND | R1 | T1 | SDA | SCL]: GPS line
Thanks Jack.
We have found the issue. It was because there is less than 2v current from the 5v pads if only connected via usb and not by battery.
Once connected via battery then the pads give 5v current.
The 4/5 pad only gives current if connected via usb.
