I have recently loaded ArduCopter on my Kakute F7 V1.2. By following the procedure with Betaflight, I managed to load ArduCopter V4.0.3 on the FC. Via USB I am able to connect via APM Planner 2.0 to the FC. The IMU seems to work well (I see the baro height changing as well) but the GPS (M8Q-5883) is not recognized.
SERIAL 4 and 2 PROTOCOL instead are set to -1 since nothing is connected there.
With this configuration, the GPS seems not to be recognized. GPS Fix and GPS Sats are always at 0.0, even if after a few minutes it is powered, the blue light starts flashing (I guess that means it has a 3d fix)
Any idea what could be the reason?
Thanks a lot : )
Emanuel
That worked! thanks a lot … I thought RX with TX and TX with RX, but apparently that was not the case. I simply switched the cables (RX with R3 and TX with T3) and it works. Thank you! : )
