GPS: No fix
Hello everyone,
I have a problem with my new NEO-6M GPS Module. On the flight data, I’ve got the message : “GPS: No fix”, and I can’t get the GPS to work.
Could someone help me ?
I already searched on Google but I found nothing that helps me.
Thank you
@Bilow,
I believe that the Ardupilot firmware is not designed for the NEO-6M or the NEO-6M has to be reprogrammed to work with the Ardupilot firmware.
Try looking at this discussion: diydrones.com/forum/topics/n … -no-signal
Regards,
TCIII Admin
@TCIII,
I don’t understand English enough in order to understand the topic you’ve sent me, excuse-me.
Could you tell me what I have to do ?
Thank you very much
@Bilow,
I am no expert on the NEO-6M GPS as it is not the GPS used with the APM which is the LEA-6. Your best bet would be to go to the DIY Drones website diydrones.com/ and see if one of the members there who has experience with the NEO-6M can help you.
Regards,
TCIII Admin
Thank you. The problem is solved : I went outside and I had the message “GPS: 3D fix”.
But maybe I’ll have problems with this GPS, I haven’t tested it yet.
Thank you for your help
@Bilow,
Inside my house, I can usually get from 6 - 9 sats depending on how cloudy it is on any given day.
Regards,
TCIII Admin
