Hi everyone, I’d like to ask a question about the GPS barometer. How much compression should be applied to the foam over the barometer to ensure that the installation is considered acceptable?
For example, when the GPS module is installed on a multirotor or fixed-wing aircraft, what should the barometer data typically look like during operation? What kind of data trend or curve would indicate that the barometer and foam installation are working properly?
I’d appreciate any advice or reference data. Thank you!
This is the flight log from a fixed-wing aircraft equipped with the GPS module I am currently testing. I think the barometer performance of the GPS module is quite good, but I am not completely sure. I would appreciate hearing your opinions. Thank you.
Flight Controller: V6X
Firmware Version: APM-Plane 4.5.7
GPS Module: M9N
Aircraft Type: Fixed-wing aircraft, approximately 1.5 m wingspan
I am simply comparing the GPS barometer with the onboard barometer and observing whether their relative relationship remains consistent under all conditions. If it does not, I would consider that an indication that the GPS barometer housing is being affected by airflow or pressure suction.
