I just got my gimbal in yesterday. If I plug only the power in it works fine. But when I plug in the 3 wires R/T/N from the IRIS into the gimbal. It rolls to a 45 deg and centers it self there. Any help would be great.
Here is the answer that I got! Go look at the link were they told you to hook up the red wire
Hello Rob.
Thank you for contacting Technical Support.
Please check the instructions shown here on the manual, note that there are some corrections to be made first:
- First ensure that when powering up the gimbal and attaching the GoPro camera, the gimbal stabilizes the GoPro camera.
- On section 3 [Connect], be sure to NOT connect the Red Wire to the gimbal.
- Note that the “Thread Cables Here” image is rotated 90 degrees counter clock wise, to ensure the same connections as shown on step #3, rotate the gimbal (Thread cables here image as reference) 90 degrees clockwise position, this will ensure same position as the images below (step #3).
3drobotics.com/wp-content/upload … RIS-V6.pdf
Hope this helps!
Have a Nice Day!
Francisco A.
[Technical Support Engineer][English-Spanish Support]
Thanks I will look them up…
Hello Rob.
Check the information on here:
copter.ardupilot.com/wiki/common-tarot-gimbal/
You should be able to see the “Configuring the gimbal” on step #6.
Download the file and write it down to the gimbal.
Let me know!
Have a Nice Day!
Francisco A.
