In case of ArduCopter, changing FS_THR_VALUE from 975 to 995, it causes PreArm check error even though throttle is 1030 on SITL.
However, in ArduPlane, following operation was okay.
- param set THR_FS_VALUE 1100
- rc 3 1110
- arm throttle <- okay
What makes this different between ArduCopter and ArduPlane?
Thanks.
I have also noticed this in ArduCopter where my throttle was at 980-ish and the FS value was set to 975 - resulted in PreArm check. Lowered the FS value to 950 and was good to go.
Thanks for sharing your experience.
Did you use a real RC transmitter?
Yeah. I am using a FrSky Taranis QX7S transmitter and an X8R receiver.
