Frame-larger-than compilation error with debug option
After some modifications, I tried to compile ardupilot (4.0.4) with the debug option on CubeOrange. Then, I got this “frame-larger-than” error:
…/…/libraries/AP_UAVCAN/AP_UAVCAN.cpp: In member function ‘virtual void AP_UAVCAN::init(uint8_t, bool)’:
…/…/libraries/AP_UAVCAN/AP_UAVCAN.cpp:329:1: error: the frame size of 1408 bytes is larger than 1024 bytes [-Werror=frame-larger-than=]
My modifications were not in UAVCAN module. My question is: which file I should modify to change the frame size (for CubeOrange)?
By the way, in this forum, I found a similar discussion under Issue building/compiling 3DR solo code
There, a need to update the compiler was suggested, but this discussion is older than the version I am currently using (gcc-arm-none-eabi-6-2017-q2-update).
I hope somebody would give me a hint!
Thank you very much in advance
You can get past thi sby using something like:
#pragma GCC diagnostic push
#pragma GCC diagnostic error "-Wframe-larger-than=1400"
on the init function
Hello andyp1per,
That worked, thank you very much!
taku
