FRAM in H743 series FC
Is it necessary to have FRAM in the hardware board when using H743 series for FC’s MCU?
Are you using another design as a template?
Have you seen FRAM used on other H743 flight controllers?
I couldn’t find any chips which looked like FRAM chips on the H743 flight controllers I have on hand. I assumed these flight controllers used the internal flash on the H743. Mateksys appears to use the H743 chips with 200MB of internal flash. If I were making my own flight controller, I’d probably use the same chip as the one used by Mateksys. I’d try to copy as much as possible from a known working design.
If FRAM is used, do you know why it is used?
It is not necessary to have an external FRAM; you can use the internal flash, and that should work fine.
For a custom flight controller, you can control the behavior using hwdef files while building the firmware for your FC. This allows proper configuration of hardware and features at build time.
Also, please make sure to choose the correct tags while addressing issues. This particular issue does not belong to ArduPlane, so it should be reported under the appropriate category.
