FPWA Mode locked UAV servos
I have a problem with the Pixhawk 6X Pro. When I fly my hobby drone, the servos lock in FBWA mode, causing the UAV to fall and crash. The flight controller works correctly in Manual mode, but I’m experiencing problems in FBWA and Auto modes.
We analyzed the flight log and did not find anomalies in the inputs or outputs — they appear normal. However, the aircraft still experiences servo lockups in FBWA/Auto. Could you please advise on possible causes (firmware, parameter settings, ESC/servo compatibility, failsafe configuration, or hardware faults) and recommend specific troubleshooting steps we should perform?
You configured it very wrong.
We need a .bin log showing the issue.
Thank you, here is link of log file for your review. please check it and if you find any problem, please let me know.
I see nothing wrong.
I would test response in FBWA on the ground. Check servo rail voltage.
