FOUND: Multicopter in Brisbane, Australia
I’m not sure if this is the right place to post this, but a few days ago I found a slightly damaged multicopter in the street in Brisbane, Australia. I googled the markings on it and realised that these are things that clearly require a bit of time and money to put together, and figured its owner is probably wanting it back - it looks like most of it looks like it could still be usable.
If you’ve lost your multicopter in Brisbane, I might have it! Please get in contact. Alternatively, if you know of others in Brisbane with multicopters (it seems like you guys have quite a good online community, I’m hoping you’ve found each other nearby as well) who are looking, let them know.
@ifoundacopter,
Thanks for the consideration, however this is more of a technical website.
I suggest that you take a picture of the multicopter that you found, join DIY Drones if you are already not a member, and create a blog post for the Forum describing your find.
Please be sure to put the picture of the multicopter at the top of the blog post followed by a description of where you found it and when.
Then delete the post here.
Regards,
TCIII GM
