I have LW20/C connected using IC2 as RNFND2 and want to use this for forward obstacle avoidance. Can this be done as I haven’t had any luck so far using the following settings
AVOID_ENABLE = 7
AVOID_MARGIN = 5
AVOID_BEHAVE = 1
AVOID_DIST_MAX = 8
AVOID_ANGLE_MAX = 1000
PRX_TYPE = 4
I’m not sure how MP knows that RNFND2 is to be used for obstacle avoidance. I tried setting RNGFND2_ORIENT = 0:Forward but then it wont work. It seems to only work when the RNGFND2_ORIENT = 25 or down.
I have a rangefinder on RNGFND1 for altitude sensing.
If anyone can help with this it would be appreciated!
I have got this working but the confusing bit is that in Mission Planner Quick View ‘Rangefinder2’ will only show a distance when RNGFND2_ORIENT = 25 or down.
Is it possible in future versions to have the Quick View show a Rangefinders distance in all orientations?
I think the advanced options may only be available on the latest beta MP. You can upgrade by going to the Help screen and then push the button on the bottom right.
The other way though is use the older version you’ve got and press Ctrl-F and then there should be a proximity button somewhere on the window that appears.
Thanks for your help and I can find the old version of Proximity Viewer.
Unfortunately I get an error when selecting 'Check for BETA Upgrades and get the following error messages.
At this point it becomes a MP issue and it’s out of my hands I’m afraid. From my own personal experience I’ve gotten around this problem by completely uninstalling MP and then re-installing it again from the .msi file.
Hi @Peterarnold
I am trying same kind of set-up with ISRT24 millimetre wave radar for downside and forward facing for obstacles avoidance also.
How was the result of this setup you was achieved…
For downward lidar i have to enable any other parameters like EK3_RNG_USE_HGT to be set 70 to use range finder for main altitude source?
