ok, so more info,
in ap_mount.cpp
function below is called;
[code]void AP_Mount::set_roi_cmd(const struct Location *target_loc)
#if MNT_GPSPOINT_OPTION == ENABLED
// set the target gps location
_target_GPS_location = *target_loc;
// set the mode to GPS tracking mode
set_mode(MAV_MOUNT_MODE_GPS_POINT);
#endif
}[/code]
this relates, i think, to the function in gcs mavlink file:
case MAV_CMD_DO_SET_ROI:
tell_command.p1 = packet.param1; // MAV_ROI (aka roi mode) is held in wp's parameter but we actually do nothing with it because we only support pointing at a specific location provided by x,y and z parameters
break;
which gets its location from
// XXX receive a WP from GCS and store in EEPROM
case MAVLINK_MSG_ID_MISSION_ITEM:
which is sent data from the follow me state.cpp file:
mavlink_msg_mission_item_send(
upstream_channel, /* mavlink_channel_t chan*/
_target_system, /* uint8_t target_system */
_target_component, /* uint8_t target_component */
0, /* uint16_t seq: always 0, unknown why. */
MAV_FRAME_GLOBAL, /* uint8_t frame: arducopter uninterpreted */
MAV_CMD_NAV_WAYPOINT, /* uint16_t command: arducopter specific */
2, /* uint8_t current: 2 indicates guided mode waypoint */
0, /* uint8_t autocontinue: always 0 */
0, /* float param1 : hold time in seconds */
5, /* float param2 : acceptance radius in meters */
0, /* float param3 : pass through waypoint */
0, /* float param4 : desired yaw angle at waypoint */
x, /* float x : lat degrees */
y, /* float y : lon degrees */
z /* float z : alt meters */
which gives the positional info used
back the in gcsmavlink function MAVLINK_MSG_ID_MISSION_ITEM:
tell_command.lat = 1.0e7f * packet.x; // in as DD converted to * t7
tell_command.lng = 1.0e7f * packet.y; // in as DD converted to * t7
tell_command.alt = packet.z * 1.0e2f;
tell_command.options = 1; // store altitude relative to home alt!! Always!!
so presume we now need to send two sets of positional data to the gcsmavlink, one lot with the waypoint for the copter, and another of the actual GCS position to film, plus an option to switch on the
