Total Noob question… I want to install my Tarot but don’t want always fly with the gopro.
Is it better just to leave the gimbal on or take it on and off ?? I know the weight will lower flight time but I am wondering if flying without the camera would cause balance issues.
Noob as well but I would definitely recommend at minimum unplugging the gimbal power when you do not have the gopro in as when it is plugged in the gimbal is expecting to have the camera weight and cant seem to compensate.
As for balance in entirety I am not sure. But taking it on or off shouldn’t take more than 5 minutes. Especially if you pick up some allen screwdrivers.
I would recommend to remove the gimbal (and not forget to apply the parameters for not having the gimbal attached). Your iris will be lighter hence more flying time.
[quote=“moombe”]I would recommend to remove the gimbal (and not forget to apply the parameters for not having the gimbal attached). Your iris will be lighter hence more flying time.
Sent from my HTC One_M8 using Tapatalk[/quote]
+1 Not to mention that if there is a crash, you have one less item to maybe have to fix or replace. But be sure to change the parameter settings…only takes a second.
