Hi all,
I just upgraded from 4.4.4 to 4.5 and lost the flowhold mode. I went back to 4.4.4 and the flowhold worked fine again. Possible bug?
Mini drone sub 250 omnibus F4 nano v6.
I attach log 4.4 and 4.5
Thanks
Hi all,
Thanks
flowhold is probably no longer included in small F4 based boards. Can you use custom.ardupilot.org to fix it yourself?
Optical Flow is not enabled by default on that old F4. I retired that board years ago.
ok thank you very much I will try with the custom FW builder for 4.5.
The strange thing is that after flying with FW 4.5 I noticed the flowhold problem and I downloaded and installed directly from the mission planner the FW 4.4.4 and the problem was solved without using the server for the CFW
