Flight logs to be used in my Thesis
Hi to all!
I’m finishing my Doctor’s Thesis. I need some Ardupilot logs of successful flights in order to check my dynamic model for the copter energy consumption.
The problem is that everybody posts logs only when facing a problem.
So, if you have some good log files like: “binary logs”, “kmz files”, “DF files” or “gpx files”, I would appreciate if you could contact me through my personal email
joaolmarins@gmail.com
Thanks in avance!
João L marins
hello,
Did you consider using SITL too ?
I think we would be interested in the result and you manuscript in return ! :stuck_out_tongue:
Hi! thanks for your prompt response!
Sorry, but what is “SITL”?
Let’s explain what I do. I get the file and change it into a Matlab (extension .mat).
I have a Matlab program that reads and plots variables from GPS, IMU and CURR. Those from CURR are essential because I’m dealing with energy consumption. I need volatge and current.
I have a model of the energy consumption and I can check my model against the energy from CURR.
http://ardupilot.org/dev/docs/sitl-simulator-software-in-the-loop.html
The energy comsumption model is really simple on simulation, but at least you could validate your model !
Interesting, maybe we could incorporate such a model into the code, I have done some work on predicting energy use for plane with a Kalman filter. I was not having a huge amount of success so I have been looking at other stuff for a bit. I never got as far as looking at copter.
I would be interested to read your Thesis, maybe you could provide some background on the approach your using?
Hi! Here is my paper! If you have some files I mentioned, please send me.A Closed-form Energy Model for Multi-Rotors Based on the Dynamic of the Movement 8 pag.pdf (957.7 KB)
