Vehicle Type: Fixed-wing UAV launched using bungee
The drone was launched successfully using a bungee launcher and initially after around 10 seconds of flight, the drone suddenly lost stability and crashed to the ground.
I have attached the .bin flight log for analysis.
Could someone please help review the logs and identify the possible cause of the crash?
I wouldn’t agree. The plane wasn’t so much flying, as being thrown into the air. It was never really in control. The plane basically pitch up and flipped over.
Another log file, 7.bin, shows a successful flight without any crash. The other two .bin files also indicate crash flights. Please check the logs .
Thank you for your response.
Overall tuning is not good. There is instability in the roll, and the pitch performance is one to two seconds behind the desired angle.
As for the take-off, I think this one was more luck than anything else. The plane still pitched up to 40 degrees (25 higher than desired) at low speed. I am a little surprised that it didn’t stall.
