Fixed-pitch tilt-rotor: pitch speed limits me to ~40 km/h, wing needs ~90. Is variable pitch the only way out?
I am building a coaxial tilt-rotor where the four arms rotate 90° so the same rotors do lift and forward thrust, and the arms themselves act as the wings. Solo build, India, first aircraft. Nothing is built yet — only motors and servos bought.
Follow-up to an earlier thread on the hover side of this aircraft: Coaxial X8 on a rectangular (non-square) layout — motor mix, roll/pitch balance, and coax thrust loss?
The aircraft
  • 4 coaxial pods, 8 × Tarot 4114 / 320 KV, 6S
  • Tarot 1855 (18 × 5.5) carbon folding props
  • 10.8 kg all-up, thrust-to-weight 1.6 at 25 °C (eCalc)
  • Rotors at ±350 mm fore-aft, ±550 mm lateral
The problem I’ve just run into
Pitch speed on an 18 × 5.5 at 5,455 rpm is 45.7 km/h, so useful thrust is gone by roughly 37 km/h. eCalc independently gives max speed 43 km/h, which agrees.
But to fly fully wing-borne on a sensible wing — 600 mm arms at 150 mm chord, 0.36 m² total, about a 2 m aircraft — I need roughly 92 km/h.
The propeller and the wing only meet at about 2.3 m² of wing, which would be a 7.5 m aircraft. Chart attached.
What I think this means: a fixed-pitch propeller sized for hover can’t reach wing-borne speed, and one sized for cruise won’t hover. To get 92 km/h at my rpm I’d need roughly 13 inches of pitch, which is about double my motor’s 500 W limit.
My questions
  1. Is that right, or am I missing something? Is there a diameter / pitch / KV combination that genuinely works for both hover and cruise on a fixed-pitch tilt-rotor at this scale?
  2. If not — has anyone here flown a model-scale tilt-rotor with variable-pitch props? What did you use, and what did it cost in weight and complexity?
  3. Is there a third option I haven’t thought of? Separate cruise propulsion, a much lower cruise speed target, something else?
I’d rather find this out now than after building the airframe.
Figures are first-order (CL assumed 0.8, no proper drag build-up), so please correct anything that looks wrong.
Without doing any maths, 10kg on a 2m wing seems mighty ambitious. Fixed pitch props on any kind of VTOL are always a compromise. The perfect prop/motor for vertical flight is not the right one for horizontal. I haven’t seen variable pitch props for planes of this size, so you’d have to custom make something. Or re-evaluate the priorities of the design. Might need a bigger wing, and a lower expectation of top speed.
Forget about using same props for both hover and forward flight. It will never work. It is either hover or forward, especially if you look for speed. For very small toys you can get away using the same prop in tilt configuration. For heavy aircraft, the weight/thrust/motor temp/motor weight budget is the most important thing.
Using coaxial motors is for me a no go, because they loose a lot of power (maybe 20%++).
And if you think about drag, the coaxial motors and props will work like a good parachute!
The problem is that for aircraft up to 6..7 kg (with 4 motors), the 3115 motors are extremely cheap (Xrotor for instance), but the options for a 10..11 kg are much more expensive (5 x).
Getting a 10 kg plane on 2 m wings is not a problem at all, you just get a higher stall speed. I had one high speed plane with 7 kg/1.3 m span, it stalled at 75 km/h, cruised at 180, and at full power was doing 290… but it did not have 8 motors as a brake.
With 1.6 thrust/weight it guaranteed to crash at some point (not during first hovers, but when there will be some wind, during transitions, at some minimal take off altitude, etc.)
Variable pitch is a no go unless you want to invent and have access to lathe and other fancy machines.
Build something simpler! If you ask these questions here, it is obvious that your project is not going to go too well.
Yes, this.
18" is equivalent to 200 class heli so swash heads for variable pitch are available :grin:. Custom bearing block with servo and motor mount would be required and we don’t have tilt heli support (yet).
