I cannot get my copter to respond when I increase the throttle. This is my first time controlling a drone so I do not know where the problem could lie.
I am using a pixhawk and everything seems to be going well. I can arm and the motors start to spin but the second I increase the throttle motor sudden turn off. Could someone pin point me in the right direction on how to control this drone manually.
I have the motor correct. Propellers aren’t attached until I can get the drone to work with the RC correctly. I am having an issue properly calibrating the ESC. I am getting constant red/blue/green flashing on the Pixhawk.
To add,
I did not realize there wis a different calibration guide here verses mission planner. It look as it may have work but do have a few question. As this is for a research project and me not having any experience in flying one there is an issue. The company that I am working with does not allow me to use a battery with out proper authorization. Sounds a bit chaotic but they are very strict with anything related to energy. With that I am using a power supply to mimic the (14.7V, 4S, 6600mah) battery into the drone until I get authorization.
Does this really make much of a difference in properly configuring the ESC?
Using the PSU I can get the ESC to react to my transmitter a bit more than I used to but it cannot reach max potential and its definitely not enough to lift the drone.
