I am trying to upgrade my boards to the latest firmware from 1.3.79 Mission Planner.
Board 1 - Pixhawk 2.4.8 (want to upgrade it to 4.3.3). The board connects with the mission planner and shows all settings. However, when I disconnect and try to upgrade the firmware, it shows a “Failed Download” error. I tried it on different laptops, but this remains the same.
Board 2 - Cube Orange (airbot mini board). The board connects with the mission planner and shows all the settings. When I click to upgrade the firmware, it shows “Failed to detect port to upload to”.
This is happening after upgrading the mission planner to 1.3.79.
Kindly help and resolve the issue.
I am not familiar with Cube’s, but I many times see similar errors even with QGC. I suppose it is because some supply error (may be supplying at the time other parts) so I connect battery and can get on (even it is said not to do it this way, there should be diodes-like inside to choose the highest supply).
When flashing, disconnecting parts help, trying to have only connected that part with the microprocessor. Also, having everything connected, a reset button.
Actually, I did not get what you said in the last para.
While connected with the MAVLINK, it asks for a bootloader update under the firmware option. There are a few discussions that recommended not updating the bootloader as it can brick the board whereas some suggested doing. Any opinion on that part?
