I recorded one of my flight, I am really not sure if the tuning is fine or not. Here is the video:
I am pretty happy to see how it works, but I think that the tuning is not best, sometimes we see the pikes in pitch and probably it can do more smoothly. But I am not sure where to see and what to check for perfect tuning. Maybe some filters need to be adjusted or pids.
Frame 8inch with 9inch props 9050. I also made the one-axis gimbal using 9g servo. Any suggestions are appreciated. If here are any professionals in fine tuning I would be happy to discuss. Thanks.
I think the tune on this craft is good as is. You could try the notch filters or just fly it. After enabling Batch logging and making a flight post the log and let’s see.
Once you have the notch set up you should be able to autotune again, and get more aggressive PIDs for a tighter tune. Are you using a 4G connection for telem and video? One other thing I’d do is update to 4.0.4. Probably won’t make a difference in flight but it has a few pretty big bug fixes.
