I’m an aviation design engineer and I spray fields with an ArduCopter build. Every spraying thread here ends with “Mission Planner’s Auto Grid is for mapping, stitch the paths by hand” — so I wrote the tool I wanted.
What it does:
- draw the field on a satellite map; drag vertices and the route rebuilds live
- cut-outs for trees / ponds / buildings — the route goes around them and they go into the geofence
- power-line corridors found automatically from OpenStreetMap
- pass spacing = swath width, auto pass angle for the shortest flight, rounded U-turns
- terrain zones: see where the field rises above your safe altitude before take-off
- upload over USB, WiFi (ELRS backpack) or Bluetooth with read-back check of every item; AUTO → pause → resume → RTL, resume after a battery swap
- GPS jamming / spoofing alarm
- phone → drone without a laptop: open ELRS backpack firmware with MAVLink over WebSocket (PR upstream: ExpressLRS/Backpack 253)
- flight log + work records in hectares (CSV), export .waypoints / .plan / .fence / KML
- planning works offline; UI in English and Ukrainian
It plans and flies the route; pump / flow control stays on the flight controller (or an onboard Lua script), since the mission is plain MAVLink items.
Try it in the browser, no install: Field Mission Planner
Android APK + source (GPLv3): GitHub - tecelskyyivan-alt/ardu-field-planner: ArduCopter field-coverage mission planner + MAVLink GCS for agricultural spraying — draw a field, generate a boustrophedon route, export .plan/.waypoints or live-upload with telemetry. Planner runs offline (satellite map needs internet or pre-cache). PWA + Android/iOS + desktop. · GitHub
It doesn’t do terrain following or variable-rate maps yet — those are on the roadmap in the repo’s Discussions, and votes decide the order.
One question I’d really like answered: what part of preparing a spray mission takes you the longest?
