Hi
I did my iris+ flight i and in between the mission iris+ did an unexpected land towards the end while it was in Loiter mode. I figured from the logs later on that it was an altitude fence breach. However when I play the logs the action displayed during fence breach is RTL where as it simply landed at its current position and not at its actual home position.
I have read that in the event of a GPS failsafe if vertical fence is breached then iris lands at its current position but the logs show that GPS fix was there all the time. I am not able to get the reason as to why did it do a land on fence breach instead of RTL. Also in the same mission I breached the circular fence too before this which worked perfectly fine and the iris did and RTL.
I am attaching the telemetry logs. It will be great if someone can throw some light on this.
Thanks
Alvika
