Feature request: parameter to disable barometer instances from EKF
I am flying a large QuadPlane (2.2m wingspan) with a Matek H743-SLIM V4. The onboard DPS310 sits in a stack where the ESC is mounted above the FC. During hover the ESC heat soaks through the board and the onboard baro reaches 80+ °C, producing altitude errors of tens of metres( reading to reading shifts as high as 2.8m). The two external DPS310s on the GPS units remain at ambient and are accurate, as this was a large drone I build with all sensors in redundancy, 2xGPS, 2xCompass 2xIMU ect ect with full intention have having two EKF lanes each with unique sensors…
There is currently no way to exclude the onboard baro from EKF fusion. BARO_PRIMARY only selects which sensor is used when affinity is off. EK3_AFFINITY assigns lanes by instance number, so one lane is permanently tied to the noisy onboard sensor. There is no BARO_USE equivalent to COMPASS_USE, and no way to mark an instance unhealthy. I’m stuck with wasted components in this build as during VTOL one of my EKF lanes is complete trash…this has already causes one re-print of my plane, when the EKF lane switched over during hover learning during the early stages of proofing the plane.
A parameter such as BARO_USE (bitmask) or BARO1_ENABLE / BARO2_ENABLE / BARO3_ENABLE would let the user keep the sensor logged for diagnostics while preventing the EKF from fusing it. This is useful any time an onboard baro is thermally or aerodynamically compromised but the user still does not want to go through local FW creation and custom HWdef.
As the current system stands I’m stuck with redundant HW that I though would be useful. I’m forced to find room for either a fan inside to move this troublesome hot air or drop down to a single EKF lane, loosing the redundancy I was shooting for in the build.
if there is any other workaround for this I would love to take it but after several hours of hunting through forums and AI queries I think I’m left with asking for this feature.
80°C on the flight stack is concernig and negatively affects all the onboard sensors with regard to both noise and reliability.
yeah, I expect as much. The actual board is nowhere near that hot (I busted out a IR thermometer) I’m Fairly sure its because buried in the fuselage, there is just no air circulation and the geometry there is just trapping hot air, it would only take a single component to get to those sort of temps (onboard FC BEC?) and I have a hot air pocket until there is forward movement across my NACA ducts which direct air into that region. Gently blowing into the gap between the FC and the 4in1 drops this down to 30-40C so I have a very small fan on order to attempt to address it…as I said in my post Ideally I would Disable those sensors entirely but that option is not available in current 4.7.1 builds.
