Is there a way where a faulty motor/propeller/ESC could be detected (potential thrust loss) and the copter would turn into a quadcopter mode to maintain attitude?
A hexacopter would convert into a quadcopter just to give it enough time to land safely and prevent further damage
wouldnt turning off another rotor corresponding to the failed motor give a better result rather than having the flight controller manage with 5 which is very unbalanced imo
like a seperate motor mixer which get triggered on potential thrust loss detection
Key to making this work is well matched components, so that no aspect of the (normal) flight is a struggle.
And very good tuning.
The old visual “yeah looks good enough to me” can be quite a different story when checking logs.
There’s reports of hex and octos landing before the pilot knew there was a major problem, so it can be done.
I believe there’s also been changes over time to prioritize stability over yaw in the event of a failure, things like that.
