I try to activate a Lua Script using STIL.
However, I can’t find the FDST_ parameters in Config.
The directories and lua script are in the STIL directory.
My windows 10 pc can’t work STIL directly in Mission Planner,
So, I activate STIL like this,
C:\Users\username\Doccument\Mission Planner\sitl>Arducopter.exe -M copter -O 36.643342,136.624265,0,0
– it works without Lua Scripting.
Suggested EK3_BCOEF_* = 16.288, EK3_MCOEF = 0.209
Home: 36.643342 136.624265 alt=0.000000m hdg=0.000000
Starting sketch ‘ArduCopter’
Starting SITL input
Using Irlock at port : 9005
bind port 5760 for 0
Serial port 0 on TCP port 5760
Waiting for connection …
Connection on serial port 5760
bind port 5762 for 2
Serial port 2 on TCP port 5762
MKFIFO failed with No such file or directory
Smoothing reset at 0.001
bus.bus=0 address=0x55
bus.bus=1 address=0x55
bus.bus=0 address=0x38
bus.bus=0 address=0x39
bus.bus=1 address=0x38
bus.bus=1 address=0x39
bus.bus=2 address=0x38
bus.bus=2 address=0x39
bus.bus=3 address=0x38
bus.bus=3 address=0x39
bind port 5763 for 3
validate_structures:490: Validating structures
Serial port 3 on TCP port 5763
I would be grateful if there was any suggestion.
Thank you.
