Fake gps to Ardupilot pixhawk 6c
I am working on an outdoor non-GPS flight and using a Jetson Orin Nano to calculate movement using vision. I want to send fake GPS data to a Pixhawk 6C running ArduPilot. I tried using MAVLink GPS_INPUT (GPS_TYPE=14) and NMEA (GPS_TYPE=5), both of which successfully delivered the GPS data. However, Mission Planner shows GPS2: 3D fix in red. How can I resolve this issue? Can the drone perform a mission in this state?
This is the python code that sends the gps data.
import time
from pymavlink import mavutil
from datetime import datetime
# Define the GPS epoch (January 6, 1980)
GPS_EPOCH = datetime(1980, 1, 6)
# Define the connection to the Pixhawk (change '/dev/ttyTHS1' to your UART port and '57600' to your baud rate)
connection = mavutil.mavlink_connection('/dev/ttyTHS1', baud=57600)
def get_gps_time():
    # Calculate the GPS week number and milliseconds into the week
    now = datetime.utcnow()
    delta = now - GPS_EPOCH
    gps_week = delta.days // 7
    gps_week_ms = ((delta.days % 7) * 24 * 60 * 60 + delta.seconds) * 1000 + int(delta.microseconds / 1000)
    return gps_week, gps_week_ms
def send_gps_input():
    # Define the GPS data as per your format
    gps_week, gps_week_ms = get_gps_time()
    data = {
        'time_usec': int(time.time() * 1e6),  # Timestamp (microseconds since system boot)
        'gps_id': 0,  # ID of the GPS for multiple GPS inputs
        'ignore_flags': 8,  # Flags indicating which fields to ignore
        'time_week_ms': gps_week_ms,  # GPS time (milliseconds from start of GPS week)
        'time_week': gps_week,  # GPS week number
        'fix_type': 3,  # 3D fix
        'lat': 254100000,  # Latitude (degrees * 1E7)
        'lon': 1212100000,  # Longitude (degrees * 1E7)
        'alt': 60,  # Altitude (meters above mean sea level)
        'hdop': 1.0,  # Horizontal dilution of position
        'vdop': 1.0,  # Vertical dilution of position
        'vn': 0,  # GPS velocity in m/s in NORTH direction in earth-fixed NED frame
        've': 0,  # GPS velocity in m/s in EAST direction in earth-fixed NED frame
        'vd': 0,  # GPS velocity in m/s in DOWN direction in earth-fixed NED frame
        'speed_accuracy': 0,  # GPS speed accuracy in m/s
        'horiz_accuracy': 0,  # GPS horizontal accuracy in m
        'vert_accuracy': 0,  # GPS vertical accuracy in m
        'satellites_visible': 7  # Number of satellites visible
    # Send the GPS_INPUT MAVLink message using the data
    connection.mav.gps_input_send(
        data['time_usec'],        # Timestamp (microseconds since boot)
        data['gps_id'],           # GPS ID (for multiple GPS systems)
        data['ignore_flags'],     # Flags indicating which fields to ignore
        data['time_week_ms'],     # GPS week time (milliseconds)
        data['time_week'],        # GPS week number
        data['fix_type'],         # Fix type (0-1: no fix, 2: 2D fix, 3: 3D fix)
        data['lat'],              # Latitude (degrees * 1E7)
        data['lon'],              # Longitude (degrees * 1E7)
        data['alt'],              # Altitude (meters above mean sea level)
        float(data['hdop']),      # Horizontal dilution of precision
        float(data['vdop']),      # Vertical dilution of precision
        float(data['vn']),        # GPS velocity in N direction (m/s)
        float(data['ve']),        # GPS velocity in E direction (m/s)
        float(data['vd']),        # GPS velocity in D direction (m/s)
        float(data['speed_accuracy']),  # Speed accuracy (m/s)
        float(data['horiz_accuracy']),  # Horizontal accuracy (meters)
        float(data['vert_accuracy']),   # Vertical accuracy (meters)
        data['satellites_visible']  # Number of visible satellites
# Main function to send GPS data at regular intervals
def main():
    while True:
        # Send the GPS_INPUT message
        send_gps_input()
        # Print debug information
        print("GPS_INPUT data sent.")
        # Sleep for 0.05 seconds to send data at 20 Hz
        time.sleep(0.05)
if __name__ == "__main__":
    try:
        main()
    except KeyboardInterrupt:
        print("Script interrupted. Exiting...")
hello, have you changed GPS_PRIMARY to 1?
I am not sure if this is the issue, I think satellite visible count is too low and hdop is too high to achieve 3D fix in real GPS case.
Yes, I’ve set GPS2 as the primary GPS. If I don’t do this, the map in Mission Planner won’t even display the drone’s location.
I have tried using an HDOP of 0.6 and satellites_visible set to 15. I applied the values from the topic ‘Faking GPS for indoor light show’, but Mission Planner still displays ‘GPS2: FIX’ in red."
hello there, when i was implementing fake gps i didn’t encounter this issues, all though i saw that your system using gps_input message from c_library_v1,i used c_library_v2 which have yaw input and for ignore flag bit mask try giving 255 or 254 if you have valid alt data… also make sure you are using compass
I tried the gps_input message from c_library_v2 and tried many different settings on ignore_flag. None of them work, and GPS2: 3D fix still displays in red. I wonder what version of ArduCopter and parameter list settings do you have? I saw your screenshot, the GPS: 3D fix is displayed in white. Have you successfully run an auto mission using fakegps?
Thanks for your help!
Hi, could you send fake gps? i have also have same problem.
