Failed to flash 4-in-1 ESC - failed to read ESC
Hi!
I have a Speedybee 60A 4in1 BLS ESC.
Bo be able to have bidirectional DShot600 I wanted to flash Bluejay with esc-configuator.com
ESC4 and ESC3 succesfully flashed.
ESC1 flashing progress bar stopped at about 98% but after rebooting the drone, it was working.
ESC2 flashing progress bar stopped at 70-80% (I was waiting for 5 minutes for something to happen, but it just stuck there :frowning: ) And after rebooting the drone, esc-configurator.com is unable to connect to ESC2.
After some googling I found, this happened to other guys and there’s an online tool to re-flash to ESC via C2 interface.
There’s another tutorial, that is using BLHeliSuite to re-flash the bricked ESC: https://www.youtube.com/watch?v=uys8h7_GxYU
Is this the only way, of are there other methods to “resurrect” my bricked ESC?
Thank you!
Log from esc-configurator.com:
2025/06/17 19:49:49: Opened serial port
2025/06/17 19:49:49: MultiWii API version received: 1.42.0
2025/06/17 19:49:49: Flight controller info, identifier: ARDU version: 3.3.1
2025/06/17 19:49:49: Running firmware released on: Mar 16 2018 08:42:29
2025/06/17 19:49:49: Board: ARCH, version: 0
2025/06/17 19:49:49: Unique device ID received - 0x01d00433034511738333333
2025/06/17 19:49:50: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:51: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:52: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:53: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:54: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:55: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:56: MSP command failed: Offset is outside the bounds of the DataView
2025/06/17 19:49:57: Trying to read 4 ESCs
2025/06/17 19:49:58: Read ESC 1: J-H-40 - Bluejay, 0.21.0, 24kHz
2025/06/17 19:50:01: Failed processing command cmd_DeviceInitFlash after 5 retries.
2025/06/17 19:50:01: MessageNotOkError: Message not OK
2025/06/17 19:50:01: Failed reading ESC 2
2025/06/17 19:50:01: Read ESC 3: J-H-40 - Bluejay, 0.21.0, 24kHz
2025/06/17 19:50:01: Read ESC 4: J-H-40 - Bluejay, 0.21.0, 24kHz
2025/06/17 19:50:01: Done reading ESCs
This step-by-step guide restored the original firmware.
After de-bricking, Bluejay can be flashed via esc-configurator.com
Solved. :slight_smile:
