Ok, so after a few more flights (link to last log) it seems to hold hover with throttle at center in Althold and Loiter. The dead zone seems to be from center throttle to one line mark above and below on the Taranis X9D. Slowly moving the throttle within those marks does not seem to affect hover, only when I go above or below.
So either there is some parameter in MissionPlanner that is critical to Herelink specifically, or a calibration issue with the Herelink controller
I had tried calibrating and recalibrating around 6 times with no luck before I swapped to the Taranis and L9R.
I am going to play with THR_DZ to see how it works with the Taranis. I had adjusted it with the Herelink with no success, but worth another try when I get to a point that the Herelink goes back in.
I setup a Dynamic notch filter using the throttle method. It brought all the GYRO readings right down, but only ACC0 X and Y. ACC0 Z doesn’t look to have changed.
I haven’t had a chance to autotune as I need to go to a bigger area. But it seems to be pretty stable in Althold. I read in the arducopter docs that is can sometimes create a tune that is unnecessarily responsive. This F550 is mostly for testing purposes, learning Pixhawk, missionplanner, and how to integrate Hereflow and a Terebee evo 60. I want it to fly nice and smooth, with no worry of aggressive flight inputs.
I suppose I could save all my parameters and try autotune. If it doesn’t work I can always reload.
I will continue to tune to try and get it dialed in tight, but not sure how much better I can get it as a noob.
My hope now is that if it is tuned and hovering with the Taranis, it should be fine with Herelink
One strange thing (off the hover topic) is the Yaw. I didn’t time it, but throughout the flight the motors would massively change pitch (as in sound) and it would yaw 10 degrees or so (I think it was nose right each time) and become a bit unstable. Nothing crazy, just a bit unstable. Then the motors would change back to a nice lower, smoother pitch and it would go back to quite stable. This happens at intervals throughout the flight. I can time it tomorrow to see if they happen at specific times (i.e. every 10 seconds).
I am uncertain if there is something I could check in the flight logs to trouble shoot.
I can take a video if that would help with troubleshooting.
Also, dkemxr, I saw in another post where you were getting 35 minutes out of an F550 (or 450?). I would love to know that setup. Your questions in the last post made me do a much longer search on battery prop combos.
I know I have a lot to learn about the math that goes into prop/esc/motor/battery combos for max efficiency. I am trying to power through, it’s just a bit daunting of a task. So many parameters that can be changed in missionplanner and conflicting information about what setups are best.
Thanks again for all of your help.
