Are there any limits to using an F405 with a GPS, compass, airspeed sensor, and lidar to perform an Autoland mode landing? I am using a Speedybee F405 Wing App and am finding that my landing attempts are quite inconsistent with the waypoint distances changing, touchdown overshoots, missed flares, etc. The sensors are all calibrated and working, so I am wondering if maybe the flight controller is saturated or if I just need to keep working on tuning parameters. I have a Matek H743 that I can swap out if needed. I had one instance where the plane made its turn to final approach a good quarter of a mile parallel to the runway and I had to use RTL to get it back to the field.
In my opinion, it should work.
A few years ago, I extensively tested automatic landing using GPS, an airspeed sensor, and LIDAR with a Matek F405 Wing in an Opterra 1.2. I didn’t notice any limitations caused by the F405. I also don’t think it requires an H743 today.
Here are a few landings from back then. Sorry about the non-English titles.
If you ran into any problems, you can upload a log file from the flight so we can take a look at it and provide more information.
Rolf
That hardware should do it. IMHO the tecs tuning needs to be spot on, and you also need to be reasonable with what kind of approaches you expect the plane will do. Generally I found even a well tuned plane will still need more room for a good auto landing than what I would do hand flying the same plane.
This. In my experience TECS really doesn’t like approaches too close to minimum throttle.
Thanks for the advice, everyone. I will keep at it.
