I must ask, its possible to run the Quicktune on a Quadcopter SpeedbeeF4Mini, exist the Script, but i cant run this on F4
have any an Idea, probably the C++ Quicktune
a few users are asking about the possibility.
No possible, With Lua script module, Stock the Firmware Builder to 93% i haved try…
Maybe you have to forgo some features, uncheck some modules.
no i have cheked, the build without lua script works nice, in builder having plane support,with vtol quicktune probably Cpp; BUT whitout parameters to enabling
As @Gregor_Enz has found, it is not really possible to get scripting running on an F4 board I’m afraid. It’s just barely possible to get Lua running on an F7 board. H7 based autopilots are really the best option if you have a choice. They can be slightly more expensive and there are certainly less options on the market but the extra CPU and memory allows us to do so much more.
i have a h7 jehmcu FC, but without SD Card, isnt possible to save the scripts on a part of ROM ??
it will work with littlefs, there is a tag in the custom build server for a 4.6 with littlefs
nice, but i not found this on the builder tap, a ok understand
