I have a bmp388 module which I want to connect using SPI, since there is already too much stuff on i2c and spi is also much faster. Ardupilot supports this sensor, but not sure if it can run on the external spi port of the pixhawk1.
I want to connect it because the internal ms5607 on spi is very noisy.
Is it possible?
if not, then can the code be modified little for it to probe on external spi?
Do you have already this module?
If yes, why you don’t try it directly?
The reason of a noisy barometer could be to much direct airflow to the sensor itself
