Ethernet Input of GPS Data to Autopilot as primary GPS
I have a USV that has a high precision GPS Compass that is outputting GGA, ZDA, HDT, and TSS1 via UDP.
I have enabled NET_ENABLED and have assigned the IP and Gateway as to:
IP: 192.168.1.20
GW: 192.168.1.1
the NET_MACADDR is assigned automatically.
I have set/tried the NET_P1_PROTOCOL to both GPS and NMEA output.
I can Ping the AP via the command prompt and can see it on the network.
How do I get the data that is being sent via UDP to be used as the primary GPS for position and Heading/Yaw?
I have checked in all of the GPS options and it does not show any way to assign a UDP port for the input source.
Cant believe there is nobody that can help…
your asking about a feature that’s just been released and is still getting worked on and is only supported on a very small number of very expensive flight controllers. There are probably a handful of people on the planet with ethernet working at the moment.
